should i be 12's???
F1atlander
Kennesaw, GA
hottwheels04
so you have stock cam still? looks like you have heads intake and full bolt ons, looks like you can get ur times down to mid to low 13's esp with that 104 trap, but if you have stock cam still best you can prob do is low 13's, maybe 12.999 with slicks and a good 60 ft of 1.6-1.8 if it is stock cam maybe a new cam and then it should be 12's all day :dontknow:
sneaky98gt
12s? Probably not unless you are launching the shitaki out of it on slicks and really banging the gears.
Lower to mid 13s? Definitely. I ran 13.2-13.3 with that trap on street tires. A 2.1 or 2.0 60' is very attainable on street tires if you know how to drive it. I know a guy cutting 1.85 short times on a stock suspension turbo 01 GT on 245 width street tires.
Are you slipping the clutch or dropping it?
JDwhite98gt
I went 12.98 @ 104 w/1.8 60ft. (Powershifting) but I had 4.10's with micky ET streets on bogarts and skinnies in the front, completely stripped passenger seat and rear seats w/ empty trunk and 1/8 tank of gas. You obviously have the power to get there but you need more practice, better tire (wider is not always better/needed). So you SHOULDN'T necesarilly be in the 12's but you CAN get there with more practice.
F1atlander
F1atlander
Kennesaw, GA
yeah those 60's are killing me because there is no "sink" in the rear of my car. i can bounce on the rear and its solid.
blue96
albrightsville pa
in near perfect conditions with a good tire you could possibly cut a high 12. lots of time at the track will pay off. my bolt on 03 gt went from high 13's to a best ever 12.8 at 105 with DR's. depends on the track too. i ran at englishtown NJ which is at sea level i believe.
Venom351R
Maine
You need to address your 60' time issue before you worry about 12's. Unless your running a lot of power you wont hit 12's with a 2.3 60'
Win
Kennesaw, Ga
You have a Stock 302 Bottom End? Those procomp heads with that stock cam are too big for that motor i think.
spdtrip
Yea again what he said lol my best is 13.12 @ 105.65 on a 1.90 60' with my cobra R's and drags so throw a nice cam in there and spray that bit#h. I dont have any spray #'s yet I scared
