Slip Yoke Rubber Ring
Boostr1
North Jersey
I'm replacing my U joints on my shaft, and noticed the rubber ring (damper I guess) on the stock slip yoke is cracked. Do I need to get a new slip yoke or is this not an issue.
Staff member
If you weren’t having any vibration issues, you’ll be fine. Some of the yokes have them, a lot of them do not.
Boostr1
Boostr1
North Jersey
Should I just remove it, I don't want to install it and later the rubber ring comes out and the metal ring slides down the shaft or damage the tail shaft housing.
Staff member
Now you are asking a question that I do not know the answer to. If it was me, I’d probably remove it.
Boostr1
Boostr1
North Jersey
if you can get it
If you can't get it coat it with grease
Coat what with grease?
Booster is that shaft ate up towards the back end it looks discolored with a groove in it
Those aren't mine, I was just showing the damper on the yoke on the drive shaft at the bottom in that pic as reference of what I was talking about.
That damper is balanced on the shaft
If that rubber o ring separates it will be unbalanced and could do damage to the tail end of your transmission and the shaft
First sighn the rubber sticks out like I see it
Second you will get a wear groove in that shaft
Like I can see
It looks like it needs to be replaced
Boostr1
Boostr1
North Jersey
Like I can see
Just to clarify, those aren't my driveshafts, it's just a picture I pasted from the Googler to show what meant. My yoke does not have the groove worn in it, but I think the rubber maybe sticking out like that, I would have to check agan.
Anywho, If I replace it do I need to take the DS to get rebalanced? If so I'll just get a regular yoke and get the DS rebalanced.
