SN-95 + Cleveland
Willautoy
I am in the process of removing the 5.0 and installing a 351c that I had built for another car I don't have anymore. Am I going to have hood clearance issues and what headers can I use? Any ideas would be great...This is going to be fun!!!
stang94X
i dont think you will have any hood clearance problems, the only clearance issue you might run into would be for the headers considering the cleveland motors are wider, i have never seen anything for cleveland headers for 94/95 stangs, so i think you might have to get a set custom made, but all in all when its done a cleveland motor in a sn95 is going to badass
Anrev
Your going to have oil pan issues too. Probably have to do customs on both. Cool idea though.
stang94X
all that is for a 351w, those will go right in, the thing is will there be clearance for headers because of the cleveland heads
G
GREG@SN95
The mounts are the same between the windsor and cleveland. You may need to do some modification to the hood/fenders. the cleveland heads and top of the engine is a lot bigger than the windsor. Headers should be pretty easy to find, fitting them in the engine bay may be a little more challenging.
Now if you had a 351W... that would be better... or at least a 351 block and lower internals...
Most guys will tell ya that the lower end on the Clevelands suck...
Finding parts for a Windsor is easier, and the parts are cheaper... Where as Cleveland parts are difficult to find...
MeanGrn Gt
clevelands are damn good motors. parts may be a little more limited/expensive but its worth it. good luck with the project O0
EdgarR213
