So I got a wierd sqeek noise
Snowed
So the [past maybe week, week and a half my stang has had a wierd sqeeking noise coming from the front drivers side. It does it mostly when there is movement of the stearing wheel, but also does it ( not as loud) when going over the bumps around town. At first I thought maybe my strut was going bad, but it mostly makes the noise when turning the wheel ( esp. to the left). The noise is really annoying, any ideas what it might be, tie rod end? Bushing? :dontknow:
2slo95fiveoh
Lawrence, Kansas
Hmm... I would check your sway bar endlinks.. They tend to move quite a bit while turning, especially if the bushings
are very worn down.. Ball Joints are another common noise complaint for the Sn95. If it is making the noise mainly
when making LEFT turns, then the first place i would check is the RIGHT sway bar endlinks, then Balljoints etc..
Snowed
it seems to make it loader goin to the left than anything, but it also does it slightly when going over bumps, hope it aint ball joints :BangHead:
Addermk2
why? balljoints arent hard to replace at all... I changed out mine in about 2 hours
Snowed
lol, its not that there hard lol, ive done them on my old truck, im just broke as all gid up right now, sucks :angry7:
95gt_stang
mine is making a squeaking noise too. I checked the balljoints by lifting the car so that my tire is off the ground and moved the wheel up and down with a metal rod and it wasnt my ball joints. Its one of my lower A-arm bushings that has went bad bc i cleaned my motor with purple power and i guess it ran down and got onto it. But let me know what your squeak was. lol
