Some questions .. ... ..
Tbuck07
Ok boys and gals!
I'm going to tear into this motor. Soon. I must get faster..Yes, everyone. The PI swap shall happen soon. BUT
I've looked into doing a turbo set up on my car. And am wondering, what would be best? My motor is starting to leak a little oil, so the PI swap would be a good thing to do.
Or a turbo. Instant forced induction power, I've always wanted to do it.
Now I know I could do BOTH..but I've heard there's no way to do a PI swap if it bumps up your compression 10:1, you could only run a few lbs of boost otherwise it would detonate your motor. I realize I'd have to have some turbo cams, different mufflers down the line (non chambered?), but whats the deal on this..?
And no I dont really want to do nitrous. Sorry :)
realitygt
how much money are you willing to spend?
cause the RIGHT way would be to get your NPI heads massaged a little bit and new springs/keepers/ valves/guides and everything. and then put your choice of cams and the blower/turbo on top of it.
but I think if you're trying to stay on a budget ( like most of us) then you could just put pi cams in the npi heads and a pi intake and then add your turbo and be done with it.
vermilion
maryland
forge the bottom to support it for a decent s/c. with a lower compression pistons. so many options. but im going to nitrous soon with a naturally aspirated motor. so im going with high compression and pi swap.
