Sounds galore
chase3203
2002 Ford Mustang Manual V6 3.8L with 60,000 miles
My car is acting a little funky. I hear a sound similar to water running through pipes. It is fairly consistent and seems to change/die down when i press down the clutch. There is also a squeak in idle that seems to disappear once acceleration is initiated. Thinking its in the clutch/transmission area.
I popped the hood to see what the problem could be if it was inside the engine. It appears that the a/c pulley (top left pulley when facing car) area is making a burning smell. Maybe the clutch? No leaks thus far from the engine, but it could be on it's way out. Seems like the car has lost a little bit of its power as well.
Besides that, it runs like a charm.
Any ideas?
slowroll96
corbin, ky
my 96 started with a similar problem, which was the TOB getting loose and fork wearing out. if thats what it is its not a huge deal at that stage but it will start chattering and grinding, and TOB will completely go and can also take the clutch with it.
