spark plug/ wires question
1996mustangGT
if you run the 9mm wires do you have to get diffrent looms/wire holders as well?
im getting the ford 9mm wires with my new plugs and was wondering....
thanks
also on a side note whats the opinions on the diffrent spark plugs?
2slo95fiveoh
Lawrence, Kansas
when i installed my 9mm wires on my car, the stock looms wouldn't fit, so i just bought a $2 pack at Advanced Auto.
as far as plugs go: NGK V-power FTW!
94Pro-5.0
Little Elm, TX
i have taylor black wire looms/separators with FRPP 9mm wires. i just drilled the holes in the looms slightly larger to get them to fit comfortably
Paul
25 cents worth of zip-ties baby! :uglystupid2:
realitygt
paul your engine has graced this forum for long now, and has mown down many a cars...all while looking beastly with zipties.
94Pro-5.0
Little Elm, TX
i never realized paul, we have the same valve covers. the ford motorsport ones arent very common.
how do i get a radiator hose like the one you have?
Paul
Nope, they stopped selling the motorsport valve covers a long time ago. That's why I kept them. :)
You would need to buy some -16 or -20 AN fittings, hose, and either buy or have an adapter made for where your water neck used to be. Oh, and you need a bung welded on to your aluminum radiator. It's not cheap; I'd recommend the money be spent elsewhere.
Paul.
