I have a 95 and I have found out that the speedometer is off by about 8mph. I am pretty sure the car doesnt have rear gears so does it sound like just my speedo gears are worn out. Are them hard to replace? Thanks
easy once you can get under the car. 1 bolt, and the vss comes out, 1 clip and the gear slides off. once you know what # of teeth or color you need just reverse the removal and your good to go. also ck the o-ring on the vss so you don't get a leak.
