Ok, found and removed the drive gear. It’s the dark red one with clip, which is wrong for my car. I need the white 21-tooth. Assuming I have the stock 8-tooth driven gear in the tail shaft.
Ordered that and should be here Thursday. Fingers crossed it all goes well and my non-functioning gauges will work!
Is that with stock rear gears or mine,which is 3.55?You need a "white" 23 tooth driven gear, not 21 tooth. All T-5's from 90 to 95 and all T-45's from 96 to 98 have an 8 tooth drive gear that is green in color. Shine a light into the trans where you removed the vss and you can verify what gear is there. 7 tooth is yellow, 6 tooth is black.
So what if we did? Remember, you’re not obligated to respond, though I always welcome constructive feedback.23 tooth driven is correct for 8 tooth drive and 3.55 rear gears.
Didn't we cover this some time last year?
My maroon one doesn’t register anything, ever. Anxious for Thursday to get here so I can pop in the new 23-tooth gear.Not if the teeth are so worn it won't pick up at all. When I put my new one on, it lasted about two weeks before it started having issues again. Now, it doesn't register anything 99% of the time.
Had the whole unit out and sent to an electrical engineer in San Jose that was recommended to my by members on this Forum. It was completely gone through and sent back in working order.It could be the cluster itself.
You do not have a speedometer cable. It’ll just be the two wires off the speed sensor.Is the (next)replacement part I may or may not need the speedo cable itself? Or ??? I’m seeing speedometer cables online anywhere from $10 to over $100. But I don’t know which one or even if that is what I need altogether. I don’t remember what things look like on the back of the gauge cluster :-(
Pretty new to it, but I take instruction well!You do not have a speedometer cable. It’ll just be the two wires off the speed sensor.
How handy are you with a multimeter?
I didn’t think that I have a speedometer cable because the only things coming off the back side of the gauge cluster are the 2 big “plug-ins”(whatever they’re called!)Pretty new to it, but I take instruction well!
