Speedometer cable question
Daryl
SoCal
Is there a clip or something that holds the speedometer cable in the transmission (T5)?
joemomma
Best I remember there's a clip. It's been a minute since I replaced my gear.
Daryl
Daryl
SoCal
And now the next logical question: what am I looking for?
Once I get the car jacked up and supported and I locate the speedometer cable going into the T5 transmission… then what??
I just revisited LMR’s Speedo and drive gear calculator. According to it, with my stock T5 transmission I would need a 8 tooth drive gear and a 23 tooth speedometer gear given my 3.55 gears and 315/35x17 rear tires.
Daryl
Daryl
SoCal
Ok, found and removed the drive gear. It’s the dark red one with clip, which is wrong for my car. I need the white 21-tooth. Assuming I have the stock 8-tooth driven gear in the tail shaft.
Ordered that and should be here Thursday. Fingers crossed it all goes well and my non-functioning gauges will work!
Wmac
Steeltown, Ontario
You need a "white" 23 tooth driven gear, not 21 tooth. All T-5's from 90 to 95 and all T-45's from 96 to 98 have an 8 tooth drive gear that is green in color. Shine a light into the trans where you removed the vss and you can verify what gear is there. 7 tooth is yellow, 6 tooth is black.
Daryl
Daryl
SoCal
Is that with stock rear gears or mine,which is 3.55?
Wmac
Steeltown, Ontario
23 tooth driven is correct for 8 tooth drive and 3.55 rear gears.
Didn't we cover this some time last year?
Daryl
Daryl
SoCal
Typo. I did order the 23-tooth. Just wanted to confirm and get some reassurance about the proper drive gear I need.
Thanks (again), everyone!
Daryl
Daryl
SoCal
So what if we did? Remember, you’re not obligated to respond, though I always welcome constructive feedback.
Or have I mentioned that before, too?
Daryl
Daryl
SoCal
So now I’m wondering this: there is the dark red (maroon?) speedo gear with clip on the trans now. Wouldn’t it render some sort of mph, even though it’d be way off?
joemomma
Not if the teeth are so worn it won't pick up at all. When I put my new one on, it lasted about two weeks before it started having issues again. Now, it doesn't register anything 99% of the time.
Daryl
Daryl
SoCal
My maroon one doesn’t register anything, ever. Anxious for Thursday to get here so I can pop in the new 23-tooth gear.
Daryl
Daryl
SoCal
Got the 23-tooth drive gear. Installed it. Speedometer and odometer STILL don’t work!
I guess I’ll look to the speedometer cable next. Process of elimination.
Daryl
Daryl
SoCal
Is the (next)replacement part I may or may not need the speedo cable itself? Or ??? I’m seeing speedometer cables online anywhere from $10 to over $100. But I don’t know which one or even if that is what I need altogether. I don’t remember what things look like on the back of the gauge cluster :-(
Daryl
Daryl
SoCal
It could be the cluster itself.
Had the whole unit out and sent to an electrical engineer in San Jose that was recommended to my by members on this Forum. It was completely gone through and sent back in working order.
You do not have a speedometer cable. It’ll just be the two wires off the speed sensor.
How handy are you with a multimeter?
Daryl
Daryl
SoCal
Pretty new to it, but I take instruction well!
Daryl
Daryl
SoCal
I didn’t think that I have a speedometer cable because the only things coming off the back side of the gauge cluster are the 2 big “plug-ins”(whatever they’re called!)
So it can be a little tricky, but if we get the pin out for your gauge cluster, you can ohm the wire from the cluster down to speed sensor connector and make sure the wire is good. We would have to find the schematic though.
Also, you can pull the sensor out and hook a drill up to the end of the speed sensor. Turn the key on and spin the sensor to see what happens.
RevJon
