Speedometer Correction Help!!!!
muzamill_717
Hi, I'm about to get my 4.10 gears installed on my 96 Mustang GT 5 SPD Manual (T-45), like in 2 days. How do I correct my Speedometer???? I already tried asking Bama tunes, they said they can't do it. Now I'm confused because all over the internet is saying either saying change the tooth speedgear, or get speedcal, but which one is the correct one?
Thanks in advance.
07GtS197
Fort Myers, Fl
Either one will do. There are calculators that will help determine which speedo gear you need. If getting a speedcal you’ll either need to buy used or get one from Abbott.
muzamill_717
muzamill_717
Ok if I don’t do it. The speedometer will be incorrect. But since I have SCT Flash tuner and it can display my MPH would that be reading correctly? Or that be affected the gear ratio change?
07GtS197
Fort Myers, Fl
It wo
It would also be incorrect since it’s reading from the same signal that needs to be adjusted.
cobrajeff96
Germany
This'll help...
I have the same 4.10 setup and the trans gear resolved my issue years ago, before I changed the gauge face which required the SGI-100BT. So you don't necessarily need to spend a lot of money to take care of your specific problem. Just the plastic trans gear will do.
cobrajeff96
Germany
Use the bluetooth phone app to setup.
I use:
Input: Low
Pull-up: On
Input/Output: High/High
Cal Value: 1.292 (though yours may differ depending on gear ratio used (e.g., 3.73, 4.10, etc.)
Freq: 67Hz
The attached photos show how I've wired it up. It's highly customized and the picture quality's not that great but you get the idea. Spliced directly from cluster harness but keep in mind that you have to make the module essentially play middle man between transmission and cluster.
