Stage 5 Cams
Mastayugi91
Guys how come nobody uses stage 5 cams on sn95's. Most guys do the stage 3 cams and call it a day. Im guessing the stage 5 would require you to do the heads because of the lift so they dont want the expense. But why dont they go with a stage 5 cam?
Sent from my SM-G920P using Tapatalk
lwarrior1016
Mr. Secondary Timing Chain
Staff member
South Mississippi
To run a cam that big effectively it takes increased compression, ported heads, lower gears, long tubes, tune, all the good stuff. If you take a stock engine and install a cam with a profile like that itll be a dog until 4K rpm. Its a lot more work that just a cam swap to make a cam that big work effectively.
Thomas_W
Capon Bridge, WV
"Stage" cams are just a marketing gimic.
When you get to the point of needing a cam that large, your going to go with a custom grind for what type of power adder you have, compression ratio, head flow rate, rpm range of the engine and how much power you plan to make.
lwarrior1016
Staff member
South Mississippi
^ Thats right and it just so happens I got a killer deal on the 278's and they fit my bill just right.
DropTopPony
South Jersey
I forgot Comp changed their advertising and combined the NPI and PI cams into stages.
Used to be:
NPI
262H
268H
274H
PI
262AH
270AH
278AH
So which one is the stage 5? Wouldn't the 278's be a Stage 6 LOL!
evilcw311
Most Evil Member!
Louisville, KY
This reminds me of when I was in high school and all the rednecls with their old beat up Chevys would talk about their 3/4 race cam's!!!!! Lol
96blak54
Staff member
Lawrenceburg Kentucky
Yea...my circle of school buddies would start chanting "foe fifty foe fifty foe fifty foe".....cause sll they talk about was swapping to a 454ci
