Starting issues
badharleymb
I have a 1995 Mustang gt Convertible Automatic transmission. I have been working on it for a while. I've added a light performance roller cam , aluminum heads, roller rockers, trick flow intake, 85mm BBK throttle body, Ford lighting mass air , BBK ignition, radiator upgrade, electric fan, larger fuel injectors and a Vortech v-1 s trim Supercharger. The starter would turn over and start the 5.0 L before I made all the changes. I have it ready for the Dyno and the starter will not engage. The starter is good, the relays are good the fuses are good and I have changed the transmission neutral switch. I need help has anyone else had this problem ?
Sent from my SM-T387V using Tapatalk
evilcw311
Most Evil Member!
Louisville, KY
Have you had someone use a meter at the starter wires while your turning the key to verify that the starter wire is getting power??
Also, has this car ever had an aftermarket alarm on it??
badharleymb
badharleymb
There isn't any power to the starter and it has the factory alarm
evilcw311
Most Evil Member!
Louisville, KY
When you turn the key on does the dash show power? Have you tried turning the lights on and hitting the key to see if it’s a battery issue? If it has a dead cell then when you hit the key it could act like there’s no power upon load.
badharleymb
badharleymb
On the left side of the engine compartment at the bottom side of the radiator is a box with the brake lines attached to it . And it makes a noise when You try to engage the starter
badharleymb
badharleymb
Yes the instruments light up, the lights ,horn radio and all work. But You don't hear the fuel pump working
that should be your abs unit/pump unless your hearing the ccrm that is not far from it. Not sure why you would hear either of those though.
When you said the fuses are good did you mean all of the fuses, or only the ones you thought were related after reading the manual? If you have not physically pulled and inspected or dragged your volt meter down them to ensure they are all good, do that first.
badharleymb
badharleymb
I have already checked each individual fuse . I'm thinking now it might be the plastic rod in the steering column
RAU03MACH
NEW MEXICO
I agree with TTOCS on ccrm , I had to replace one once I had no power till I replaced the ccrm . check voltage on that plus the relays
evilcw311
Most Evil Member!
Louisville, KY
Pretty sure ccrm has nothing to do with the starter or power to the ignition switch
badharleymb
badharleymb
I replaced all of them
I replaced the ignition electrical today and checked the rod that operates it also and it was good. All I can do now is check for broken wires
Pull the starter relay out of the fuse box. Test to see if pin slots 85/86 has power on with the key in the start position.
badharleymb
badharleymb
I did and it doesn't. I started under the dash tracing the pink and white wire but I haven't finished yet
does the pink/white have power on it when in the start position? Also now to be clear I am saying in the start position, not the run position. It should only have power on it while the starter would be cranking and will be off even in the run position.
