steeda tri ax short shifter
aarons_4six
can someone give me the thread size and bolt length needed for a 96 gt, also it didnt come with the isolator either, would i be ok ifbi trim the stock rubber?
joekd
Ct
Call Steeda. When I bought my tri-ax used it didn't have the bolts either and they gave me the exact specs on the ones needed.
They should be able to answer the iso question as well
A
aarons_4six
yeah i figured i should call, but ive had bad experiences with tech help before from manufacturers
A
aarons_4six
the steeda shifter comes with 6 bolts. 4 for the mounting, 2 for the shift adjustments. they are longer than factory because of the shifter base
joekd
Ct
ttocs said:
I just swapped out my shifter yesterday and didn't need any bolts, which ones do you need?
The 4 bolts that hold the shifter to the transmission need to be longer then OEM for the tri-ax simply because the base plate is thicker
