STEERING Wheel Vibration
Thomas_W
Capon Bridge, WV
Not sure tbh!
when i first got my 99, it had a vibration in the steering wheel. Im not sure what got rid of it though bc i replaces the outer tie-rods, A arms, K member, steering shaft, C/C plates, coilovers and rack bushings all at the same time. I dont have a fromt sway bar, so didnt bother with endlinks.
JerZeyStangz
Northern NJ
I'll check the shaft. Swaybar endlinks and swaybar bushings are new.
Are they modified end links or just stock with new bushings? M/M recommends you get there modified links if your dropped low. My shimmy happens when the car weight get unloaded from weight bouncing when it dips on highway. Did you do your rack bushings yet?
the5.ohh
the5.ohh
Shaolin, NY
They're shorter than stock, so modified yeah. Rack bushings are original
JerZeyStangz
Northern NJ
Shaft will give play in the wheel stationary, bushings will give play in the steering at higher speeds.
alleghenyamerican
