Stereo redo is finally done
joekd
Ct
Finally got the last pieces done on the Mustangs stereo redo. Only pieces reused were my barely broken in Infinity Kappa speakers (6830CS 6x8" components in front and 63.9I 6.5" 3-ways in the rear) Infinity Basslink sub, Sirius Sportster dock and AUX jack in the ashtray area of the center console.
Ran new 4GA power wire from the alt back (was going to run 0 ga but honestly do not need it with the pieces I am using) to a fused dist box in the trunk so it splits to a 4ga feed for my new amp and 8 ga to my basslink
Next pulled out the seats and interior panels so I could run new 14 ga wire to all speakers and new RCA's down the middle of the car for front, rear and sub as well as turn on wire. Few people recommended duct tape to use to hold wires in place but ended up picking up a roll of Gorilla tape (cheap, easy to work with and black in color) and it worked perfectly.
New HU is a JVC Arsenal series KD-AHD79 (3 sets of 5v preamps, HD radio which I will likely never use, front USB with Ipod/Iphone control, front and rear AUX (necessary for my Sirius and existing AUX jack wiring) more color settings then I could ever need and a nice small keychain remote
Amplifier is a Kenwood KAC-8405, 720W peak power, 75Wx4 RMS and built in cooling fans. Built amp rack out of 3/4" MDF so that it mounts the amp in a way where it can get good airflow while not taking up too much trunk space. Was debating over carpeting it and enclosing the sides but once I rounded the sides using my router and gave it a couple coats of semi-gloss black paint I really like the way it turned out and think I will leave it this way so I still have easy access to the wires. I also routered 1/2" channels into the bottom of the wood so that running the wires under it is easy to do and does not leave them pinched.
On to the pics
Head unit and Sirius unit
With IPOD cable attached
Ipod touch in the glovebox. Got it for free from my daughter after she upgraded hers. This one has a broken home button which was beyond annoying to her but is great for me since I can control it from the HU and remote.
Amp with custom trim plate, was just plain black so I redid it in silver then added the pony I had leftover from an old GT grill
Infinity Basslink
New trunk view lit up with dual LED stips
Sound is pretty much exactly what I wanted, it is stupid loud but still crystal clear at any volume level with good low fill from the Basslink but no overpowering bass.
I really like the Ipod control more then I would have expected. The HU will charge it as well so I never have to touch it unless I want to change the songs on it.
joekd
joekd
Ct
BTW - total time for doing everything was just under 10 hours over a week long period working alone
To say the least I am glad it's all completed
sn95jones
Arlington, Tx
I've been debating on a new headunit =\ I like my OEM headunit because it's stock but I do want to be able to stream Pandora from my stereo =\
g36 monkey
Orlando, Fl
I really like the pony on the amp. I made a speaker box and covered it in trunk liner and debated cutting out a pony to put on there and add lights into it that go along with the music, etc. Just, one of those things you never get around to ha
