still missing
RED guy
Guys My 96 GT is missing
i ve change evrey thing plugs,wires,injectors,etc
and its still missing :crying:
my mechanic said its from the Intake manifold gasket
and other guy said its of course the oxygen sensor
please help :wall:
Nater
Are there any error codes popping up? When you changed out plus, did you notice any that were fouled?
R
RED guy
the guy that said its from the sensor he installed a flash programer
R
RED guy
so what do you think
from gasket or sensor
is there anyway to know if it from te gasket?
Nater
The intake gasket will not cause it to misfire. The only thing that I can think of is that the gasket is not sealing correctly and allowing coolant into the cylinder, this causing the misfire. You really need to find out on which side the misfiring is occuring and on what cylinder. Once you do that we can help isolate the problem.
Pennywise2
Did you change your coil packs?
Your coil packs could be bad and causing the miss?
R
RED guy
yasterday i met a guy and he said he have the same problem and he told that his IM gasket is bad.
yes the coils packs are new
But any buddy get this problem from oxy sensor?
