stock injectors or 24lbs.
QCmustang94
I have a 94 gt with gt40p,e303,cobra intake, full exhaust. I'm just wondering if I have to change my injectors/maf for 24lbs or my stocker would be fine?
the stock cobra would have had them, you are at the point where it is really close and IMO I would do it.
94svtturbo
If you need a set of 24's PM me. I just put the 24's out of my 94 cobra over this past weekend
If you're changing injectors you will either need a MAF calibrated for said injector size or a tune to run properly. I'm pretty sure with that setup though the stock injectors should be fine.
Q
QCmustang94
Yes I have a MAF calibrated for 24lbs injectors but I think that my MAF doesn't work. So if you say I'll be alright with the stock ones i'll stay with them thanks!
Musturd
What do you mean ? You think it doesn't work did you disconnect the battery while changing maf sensors
