stroker, but want to find out bout heads
stangdriven
ok, i know there is probably another thread like this, but this is the only way i know ill get my answer, i plan on doing either a 408 or 428 stroker, aftermarket block yes....i plan on doing a f2 procharger at 20lbs of boost or so, just wondering what cc heads i should be looking into, i have looked into afr's alot but just wanna see what you all have to say?
NXcoupe
Speaking from experience, I like the TFS twisted wedge R 225 heads for the kind of airflow you are talking about, you can also look at the step down from this, the non CNC version is a smaller port volume. Really the intake isn't the restriction in high hp blown applications, it's the exhaust. This is because you are forcing the air in anyway, so even a poorly designed head, like a stocker, will still produce decent power in low boost situations. In high boost, the exhaust becomes a restriction because for example, if the intake and exhaust valves were both opened for the same amount of time, and the same lift(this is why dual pattern cams are superior), the pressurized intake side can move in more volume than the exhaust which is not pressurized can move in the same timeframe, this is even more evident in a turbo application. Also the AFR 225 is a decent head. The minimum you should look at is the 205 of Trick Flow or the AFR. There are also cheap chinese rip offs of Vic Jr. heads out there too. there are a lot of possibilities, but these are two of the more popular ones.
LAFENATU
If your gonna do a blown 428 I assume this is going to be a race car or a weekend car?? I would look into a few different heads.
Edelbrock Billy Glidden Heads
Brodix (I wanna say M1???) heads
AFR 225
TFS R Series heads.
stangdriven
well no its not a complete race car, ive always wanted to build and to have a big cubed mustang with a hell of a lot of power.....but i also do know i dont plan on driving it on the street that much anyways. but thank you guys, at least you guys said it sraight up without extra bullshit that i dont care for...thanks again, if i have any other ?'s ill post on here for ya for the heads of course
stangdriven
also i should have brought this up when i first brought the thread, umm....what intake manifold for lower and upper would you guys recommend or suggest me to look into??
stangdriven
oh god no, thats why im doing all of this over time but im fully aware of how much its goin to cost me though...but thats why im starting with the motor first...
NXcoupe
Well, for the intake it depends on what you are wanting, but since you are planning a big blower, then I would go with Edelbrock's super victor carb style EFI intake they are selling. They sell the intake, and rails, the elbow you can buy from Probe. You are going to have a ton of torque, so no need for a long runner unless your car is going to be super heavy, then I would say go with what my vert has and use the TFS R box setup. No way this thing could ever require a long runner intake. jmho.
stangdriven
ok im looking for that super victor carb style one, and i dont know if im finding it, if you can send me a link directly to it, i did find the elbows,
NXcoupe
Go to summit.com and search edelbrock, and click on efi intakes. Then look through and you will find an intake that looks like a carbed one, but has injector bungs made into it.
stangdriven
ok i think i found the right now, looks like a carb design but has injector bungs, now you said that would allow massive amounts of torque?
LAFENATU
No it won't allow tons od torque. With a 408/418/428 etc...there is no need for extra torque.
I would recommend the exact same intake as well.
