What does "leaking down and washing the maf" mean?
Leaking down: Water/methanol fluid left in the nylon tubing is sucked out by the engine vacuum and this fluid flows or dribbles in the opposite direction of the engine/throttle plate.What does "leaking down and washing the maf" mean?
That’s exactly what I was going to say!! HahaLeaking down: Water/methanol fluid left in the nylon tubing is sucked out by the engine vacuum and this fluid flows or dribbles in the opposite direction of the engine/throttle plate.
Washing the MAF sensor: Under harder acceleration, the "leaked down fluid" gets picked up and is blown over the MAF sensor. Repeated cycles of this will eventually destroy the MAF sensor.
Fix: Install your Water/Methanol Injection nozzles behind your throttle plate and use a good solenoid close to your nozzles.
I hope that helps
Michael Plummer
Weird part is I have a solenoid…but it’s in the trunk.Leaking down: Water/methanol fluid left in the nylon tubing is sucked out by the engine vacuum and this fluid flows or dribbles in the opposite direction of the engine/throttle plate.
I hope that helps
Michael Plummer
Solenoid in the trunk: The engine vacuum pulls the fluid out of the nylon tubing or line length. The bottom line, the solenoid should be placed close to your water/methanol nozzle. In your setup, you should have used two solenoids.Weird part is I have a solenoid…but it’s in the trunk.
I also replaced the MAF at one point and it still ran like shit.
Appreciate the feedback man. You actually sold me this kit back in 2014 as part of a group buy on a different forum. Full circle a decade later after I finally installed it.Solenoid in the trunk: The engine vacuum pulls the fluid out of the nylon tubing or line length. The bottom line, the solenoid should be placed close to your water/methanol nozzle. In your setup, you should have used two solenoids.
MAF: Once fluid hits the MAF sensor, your car will stumble and buck. It doesn't need to die for it to have a driveability issue. And you have other issues causing your bad driveability (easy to do when you don't know).
I hope this helps
Michael Plummer
you would....i moved that sensor to the lower intake when i did the blowerah I see now with the solenoid in the back. Correct me if I am wrong but don't you want the nozzle in front of the AIT sensor?
MichaelSolenoid in the trunk: The engine vacuum pulls the fluid out of the nylon tubing or line length. The bottom line, the solenoid should be placed close to your water/methanol nozzle. In your setup, you should have used two solenoids.
MAF: Once fluid hits the MAF sensor, your car will stumble and buck. The MAF doesn't need to die for it to have a driveability issue. And you could have other issues causing your bad driveability (easy to do when you add parts without a tune or don't know).
I hope this helps
Michael Plummer
that makes sense. believe the valve has 7psi crack pressure so assume vacuum would open thatmr plumber would be the expert here by all means but if I am thinking about it right I don't think so. It would prevent it from going back to the solenoid but the vac being drawn from the intake would still allow it to pulled out forward. I set up a meth system in my car but I have not filled or used it yet because of one thing or another but I will have to show you how I put my solenoid on the TB. It is a tight fit but it should work.
