Sway Bar Width
spittinfire
I'm hoping someone here might have the measurements I'm looking for because I can't find them anywhere. I'm trying to find out the width of the sway bar mounts and the width from end to end on an SN95 front sway bar. I want to put a new bar on the front of my 88 Turbo Coupe which I've 5 lug swapped from a 95 Mustang. The Turbo Coupes used SN95 control arms and had similar width so I'm thinking an SN95 bar might be a better fit then an Fox body. The problem I'm seeing is in the bushing mounts because the Tbird had mounts welded to the inside of the frame like a Fox where I believe the SN95s mounted directly below the frame rail.
STITCHSCREWW
