Tail lights
the5.ohh
Shaolin, NY
Gonna be tinting my tail lights, 3rd brake light and rear side markers pretty soon once the nice weather comes. Going to be using Rustoleum Lens tint. Should i wet sand the lights first? If so what grit. I've read on different forums that the Rustoleum is a lot better to use than VHT because it comes out glossy not dull. I'll be doing the sidemarkers and 3rd brake light on the car and I'll probably take the tails out.
chrisv_10
Asherton, tx
Sand with 1000 grit and use adhesion promoter before spraying the clear.
Sent from my A500 using Tapatalk 2
the5.ohh
the5.ohh
Shaolin, NY
Good write up. I think it's definately do able with the horizontals, can't wait to do this. I'm gonna print out your write up and follow everything you did. Thanks man
chrisv_10
Asherton, tx
Wet sand 1000 grit, dry it, clean with alcohol, spray adhesion promoter, let it dry 5 mins, spray the tint and you're done . You can buy a can of adhesion promoter at Walmart or any auto parts store.
Let it dry for a day or two, wetsand with 2000 and start hand buffing using a rubbing compound followed by a swirl remover. It will come out shiny as hell.
Sinned83
MA
Nope sealant is what I used instead of clear because I had a problem with the clear wanting to bubble. 1000 grit sand paper will still leave sanding marks you will want to use a couple finer grits IMO
chrisv_10
Asherton, tx
1000 grit will not leave sanding marks. Is gonna be pretty hard buffing out the horizontal tails with a buffer. You will have to do it by hand.
Sent from my SGH-T679 using Tapatalk 2
the5.ohh
the5.ohh
Shaolin, NY
This is kinda confuzzing me. Am I good if I just follow that write up in the link? Ah so the clear gave you an issue. What brand was it?
the5.ohh
the5.ohh
Shaolin, NY
So basically spraying the clear on is the absolute last thing to do, no wetsanding or buffing after?
chrisv_10
Asherton, tx
Oh I didn't see the party where you said you were spraying clear. Do the steps I said. Let the lens tint dry a couple of hours, preferably out in the sun. Once its dry enough, wetsand with 1000 being careful not to sand through the tint. Dry it, clean it with alcohol and spray the krylon clear, be careful not to run it
chrisv_10
Asherton, tx
Let the clear dry a day or two then wetsand with 2000 then follow the buffing process.
chrisv_10
Asherton, tx
I've tinted alot of headlights and tailights with no problems. I spray a tinted clear though, but I've done the rustoleum tint a couple of times without a clear over them and they turn out good after done wetsanding and buffing.
cleared mine and they have held up nicely for over 5 yrs now. Get a good quality that has a good UV resistance and they should last a long time.
GTfiveoh
Des Moines, Iowa
Another key to getting it glossy is finding the right distance to spray, if you're too far away it will look very dull, but if you're too close it will run so you want to find that happy median. And never stop spraying on the light, always start off the light glide over the light and finish off the light.
Sinned83
MA
I used the rustoleum it's the best I've used or seen used yet. Nightshades seems to get flat looking. Whatever way you go don't skip on the prep work that's the most important step.
the5.ohh
the5.ohh
Shaolin, NY
Thats what I've heard. A friend of mine tinted his tails on his gran cherokee with rustoleum and they came out real glossy. I'm gonna take my time with them for sure. You guys get your balls busted by cops for the tinted tails?
twisteddalek
