tensioner pulley removal....
F
free_ryde
there is a high pitched squeak coming from around that area, ive removed the other pulleys so i'm assuming this has to be it. when i look at it, it only looks like the one bolt in the center
F
free_ryde
thats what i ws thinking, just thought there might of bin a bit more to it. thanks
Goldmember
Cornwall, NY
Are you talking about the idler pulley (near the water pump) or the pulley on the belt tensioner?
The idler in the timing cover is easy, the one on the tensioner is too but I took the tensioner off the car, wedged it in a cinder block, then loosened the bolt holding on the pulley. I suppose a table vise or something would get it done too...
uncltrvlnmatt
Pa.
I just changed mine. You can't get just the pully. You have to buy the whole tensioner. If I remember right, it was about 80 bucks. I went to 2 different Ford dealers, they both told me the same thing. I ended up nuying a tensioner from Advance Auto.
uncltrvlnmatt
Pa.
free_ryde said:
i'll just hit up one of the auto wreckers out here and grab one off a 4.6
IMO, with something like this you are better off new. The belt tensioner takes a constant beating.
Goldmember
Cornwall, NY
Perhaps the 4V is different but I bought two idler pulleys, and simply unbolted the old idler from the tensioner and replaced with a new one. The idler on the tensioner is the same part as the one in the timing cover.
Nonetheless +1 on replacing the tensioner, I took the cheap way out...
F
Firestrike87
Guest
I have a squealing noise I can't find either. Although mine sounds like it is coming from the alternator but it sounds fine? Did it squeal all the time?
Goldmember
Cornwall, NY
I suspected my alternator too, and yes mine did squeak all the time. Replacing the idlers fixed the problem. (And boy was I glad I didn't have to pony up for a new alternator!)
