The FIND a car for Mike thread.
98Viperblue
Re: The FIND a car for Mike thread.
Going to get the cobra today guys.
Expect either a build thread or a part out thread soon!
5.0kid
Re: The FIND a car for Mike thread. (Update post 81!)
sorry, which cobra?
Win
Kennesaw, Ga
Red one in Va about an hour away from us. Rear Quarter Damage
Shame302
Yeah, I'm with you on that. I'd snag it and part it out.
Win
Kennesaw, Ga
Yeah my suggestion when i saw it also. +1 :)
:eek:ccasion14:
5.0kid
yup, very good deal! good luck with the part out if thats what u decide!
98Viperblue
Fml. ****** sold it on me.
Said a guy offered more..
Oh well. Back to the drawing board.
white95
Apex Junky
Admin
Prairieville, LA
$1000 lol come get it
98Viperblue
Should I re-name this thread find a MUSTANG for Mike thread.
^interested pm me.
cantbuytime
man that car on corral is a hoss.. I bet u could get that for reasonable...
There are tons of mustangs here.
http://houston.craigslist.org/ctd/2090000319.html
http://houston.craigslist.org/cto/2088366680.html
http://houston.craigslist.org/cto/2071679052.html
http://houston.craigslist.org/ctd/2025101766.html
http://houston.craigslist.org/cto/2083896569.html
http://houston.craigslist.org/cto/2069588451.html
i would do a craigslist search in all major cities within a reasonable distance. You can always fly and drive back if the car is nice!
Win
Kennesaw, Ga
I know your not to fond of a fox body but i found an 89 for 6g with a built motor and everything.
Here is the Photobucket
http://s23.photobucket.com/albums/b354/mustang8573/Mustang Sale/
List of whats done to it.
Brian @ 703-629-2689
I work midnights and sleep during the day so please text, don't call and wake me up!
NO TRADES.
The ONLY reason I'm selling the car is because I am having a child the end of October. The car does not have A/C (although I do have most of the parts for the AC that will go with the car) and it's too loud for an infant to sit in the rear seat. I truly hate to see it go but I have no choice. Car seat does not fit either.
STOP TEXTING ME ASKING IF I WANT YOUR MOTORCYCLES OR ATV'S, SERIOUSLY?????
*****PRICE DROP***** $6,000
I'LL TAKE $5,500 IF YOU BRING YOUR OWN WHEELS
The pictures do NOT do this car justice. I life in the Fredericksburg, VA area and we can go for a ride any time you want.
Here are a list of the parts. I'm sure I've forgotten something. You will not find a cleaner Fox in the area, I guarantee it! The motor has 1,000 miles on it and the body has 150K. The paint, weather stripping and molding is all under 3 years old. Issues with the car is: passenger electronic lock switch does not work and there is a fixed rust spot on the passenger side fender. There is something loose on the front end related to the steering, can't figure it out.
Engine
DSS 331 short block $1,999.99
Trick Flow Twisted Wedge heads 170/66cc $1,199.99
ARP head bolts $44.95
Trick Flow TFS-51400265 thermaplug X 2 $19.00
Fel-Pro Z10112 head gaskets $37.95
Fel-Pro Z1250 intake manifold gaskets $22.95
Trick Flow push rods $44.95
Trick Flow 1.6 black rockers $269.95
Trick Flow stage 1 cam $169.99
Ford Racing double roller timing chain $64.99
Ford Racing valve covers $100.00
metal valve cover gaskets $50.00
Melling oil pump shaft $11.95
OEM oil pump $34.99
Fel-Pro one piece oil pan gasket $31.95
Trick Flow Track Heat intake manifold $529.99
PVC pick up screne w/rubber gasket $26.98
Cobra 24lb ful injectors $129.99
Accufab fuel pressure regulator $129.99
75mm throttle body $149.99
75mm EGR spacer 2" $30.00
TPS $35.00
C&L 76mm 24lb mass air system $229.99
K&N cone filter $39.99
OEM style 28oz balancer $89.60
OEM cap/rotor $11.25
AL radiator $100.00
Autolite 8mm ignition wires grey $40.00
EGR delete electronic plug $23.99
coolant temp sensor #1 $5.94
coolant temp sensor #2 $10.87
OEM water pump $40.00
OEM heavy duty fan clutch $50.00
3G Alternator $149.99
MARCH adjustable alternator bracket $100.00
BBK silver underdrive pulley set $119.99
Convertible motor mounts $80.00
Champion spark plugs $12.00
Suspension
Eibach Pro Kit springs $224.00
KYB struts $300.00
welded sub frame connectors $130.00
Brakes
Power Slot front slotted rotors $200.00
OEM rear dum pads and new spring kit $49.99
Wheels & Tires
89 Saleen SC replica rims 17x8 / 17x9 $500.00
rear tires Can't remember brand, but paid $280 for them
front tires Can't remember the brand but paid $400 for them
Exhaust
BBK shorty headers $180.00
Pypes catted X-Pipe $323.99
Magnaflow cat back exhaust $489.99
Ford Racing 28oz steel flywheel $239.99
SPEC stage 1 clutch $228.99
UPR clutch calbe kit w/fire wall adjuster $79.99
Rebuilt T-5 transmission $450.00
Ebay AL adjustable shifter $63.00
Misc
Autometer oil pressure gauge electric $71.30
Autometer water temp gauge mechanical $43.00
Autometer gauge pods x2 $40.00
Walbro 255 fuel pump $95.00
I know with all the mods it could use a tune, has a little shake. It pulls like crazy!
Just did a compression test and it read 180 on all 8 cyl's.
Win
Kennesaw, Ga
Another
Price:4500
contact info: text or call 540 840 5663 or reply or pm me
The car has a worked gt40 motor in it. It has gt 40p heads,holley systemax upper and lower intake, bbk 75 mm throttle body, mac elbow adapter for the throttle body, 24 lb injectors, granatelli motorsports 75 mm mass air meter calibrated for 24 lb injectors, high volume oil pump, holley 255 lph fuel pump, zoom performance stage 2 clutch kit, steeda tr ax shor throw shfter with pro 5.0 base plate, bbk shorty headers, bbk off road x pipe, mac mufflers, 2002 mustang gt center console, 2002 mustang gt wheels, ford motorsports 3.55 gears professionally installed, foxbody conversion harness with a3m reman 1993 ford mustang 5 speed ecu, frd motorsports underdrive pulleys, msd 6al box and msd coil, smog pump eliminator bracket. ac blows cold heat blows hot. black leather interior. black carpet. the car is black cherry pearl with a white cobra r bolt on 3 inch hood. it also comes with a wingless trunk, new passenger door,new driver fender. It has kyb gr2 shocks and struts also.
the bad
it needs a couple minor things like abs sensor, driver side window motor. the car needs to be repainted due to passenger damage.
video of this car is on youtube.com
for any info text or call 540 840 5663 phones always on
