Throttle cable
Randy
I just changed my upper and lower intake to a Trick flow track heat and I used the trick flow elbow adapter also .. And now my throttle cable is about an inch too long so my pedal is about half way down from where it should be.. I was thinking of soldering the strands on the cable together before cutting it and then drilling out the cable on the end piece that hooks to throttle body and then re-soldering it back on.. Unless of coarse there is an easier way. After I get back from bidding on a few jobs I will take a few pictures if needed. Thanks Randy.... I also changed the throttle body from 65 mm to 75 mm..changed maf air meter and put on a bbk cold air intake
Staff online
