Timing cover ?????????????????'s
ferrer5300
Hi I am coming close to the end of the pi head swap and have got a question.Can you use the 04 romeo timing cover or do I need to buy a 98 timing cover?I no longer have my 98 it cracked when I was removing cause of the stupid power steering bolt.I went to 50resto and they sell a timing cover listed as 96-04 timing cover curious if its the same timing cover for all romeo blox.any experience out there that can help out?
bottlefed97
Orlando, FL
I have a timing cover off my 97 gt, on a cobra block w/P.I. heads and it fits fine... You should be fine in your case though.
F
ferrer5300
I dont know if the later models changed something though I think it fits because maybe its the same year of cobra and gt...is it?
96-04 romeo use a different sized bolt than the 96-04 windsors... just buy the new bolts and you should be fine.
F
ferrer5300
yeah I think the tensioner is different but I still have my coil brackets and it looks like they fit I kinda mocked it up
'what did anyone else with a pi headswap use?
glittle75
i didnt tear up my original, so i reused after i cleaned it, but it will work.
if you get one from a 99-04 it wont have mounts for your coil packs, and if you get one from a windsor you will have different size holes where it bolts into the heads.
and yes ours had 3 bolt tensioners, later models had 1 bolt tensioners, and some have 3.
long story short, it will work, but might take little more time and new hardware.
bottlefed97
Orlando, FL
MustangChris said:
nothing a little JB Weld cant fix ;-) lol!
Hey man by the way, I ended up not getting that 2.2 KB, I got a Saleen Series II blower kit... So the hood stays:/ lol
