tire size?
Lebedin8654
I have a 94 GT with 97 or 98 i think but they are cobra rims what size tire can you put on the back i need some better traction!!!
Stangbangin
if they are 8 in wide rims the widest I'd go is maybe 255 or 275. 275's are gonna give you alot of bulge.
Downshift
Yeah exactly what he said. The bulge you can live with though and you would have 275s. If they are 9 inchs then there is no problem than.
I have 275 Nitto DRs on my 8" rims and you can see the middle is wearing faster than the outside. Stock my car came with 255s so I assume the rim is wide enough for those with no problems.
Downshift
Sounds like you have too much tire pressure in your tires what psi are you running? Usually thats the culprit.
916_5.0
I have 275s on my 95 cobras and they dont really buldge much at least from what i can see and they dont wear down in the middle its pretty even.
Downshift
I dont think you have put enough mileage to be able to tell. Plus he had DRs and you have street tires.
Win
Kennesaw, Ga
I had a set of 275/40 on my factory Tri bars and i had my psi at 28 and still wore in the center there is really no getting around wearing in the middle. They didn't have any buldge either they sat flush with the rim. There were a PITA to get on though took me about 15 min a tire. I would just look at getting a set of rims or go with 255 thats the widest i would go with.
fast5oh
yup every set of 275's i have had always wore down in the middle no matter what did it on the nitto 555r extreams and some eagle f1 and some fusions
Drew2o2
tri bars are 9inch wide. The cobra wheels are 8. I have 275/40r17 on my tribars and i wouldnt put them on any smaller of a wheel.
Slow95Cobra
only fatory 9 inch wheel is the R's and 03-04 cobra... tri bars were 8's, same with 94-01 cobras.. and i only run 24 psi in my nitto drag rad's.. wearing even since they have been on. 275 is as wide as you should go on a 8 inch wheel. ive seen pics of a 315/35 on a 8 inch wheel.... to unsafe for me, but... to each there own
Paul
I have 275/40/17 Nitto Drag Radials on my 97 Cobra wheels with no issues.
