Too much lift with p heads???
birel21y
Hi Guys,
Is there some way to calcualte if i will have too much lift with "P" Heads E303, and Cobra 1.7 RR's on OE bottom end? Thanks, Alex.
LAFENATU
I have yet to hear of anyone having clearance issues with a GT40/GT40P and E Cam setup BUT I would recommend checking anyways. Every motor is different..
B
birel21y
are the clearances the same between GT40 and GT40P heads? i ran regular GT40 (cobra) heads on ,y race car with 1.7 rr's and an E303 just fine...
RycheGT
The P heads have larger valves. 1.84 I believe? If you use a 1.6 rr youd be fine more than likely. Theres always the possibility of a problem. Each engine is different no matter how similar they are.
B
birel21y
Are you sure? I thought they has identicle In. valves, but smaller exhaust valves.
