OxmanWI
This project started a year and a half ago, but I thought I would post past progress to current date.
4/28/11
After buying my Thunderbird back[/URL] from a local who basically trashed the car and let it sit, the time has come to start working on the Thunderbird and bring her back to life. As you can see there is minor body damage to the fender and headlight panel, nothing I can’t handle with parts from the salvage yard. I’m keeping the stock NPI block for now, it’s only got 91K+ miles on the clock. There’s no need for a PI motor swap when I have a perfectly good motor to blow up.
Other than that, just trying to restore the look and finish from what she used to look like before the carnage.
Before Picture:
01-10-2012
I talked with Bill at Tork Tech / Supercoupe Performance and this will be the first Thunderbird with a Terminator kit. Ever since they came out I've always wanted one really bad. From the Allen to the SVO and now a Tork Tech Terminator kit. I'm hoping this is going to be the last Supercharger that's on the car.
As of right now I’m working on getting the block and heads sent to my engine shop, but they are booked solid for the next couple of months. I need the rotating assembly balanced with the new dish pistons and the block bored out to .020 over. Compression would be around 9.2:1 and something around 15 pounds of boost. I have no idea what kind of power this set up is going to make.
Thanks for looking!
Josh
Engine Block
97 Cobra Teksid
Cobra Crankshaft
Eagle H-Beams
Keith Black 21cc Dish Pistons
MV Performance Ported PI heads
- Ferea Valves
- Comp Cam Springs,
- 9 threaded SP holes
- GT rockers
- MHS Stage 2 Blower Cams
TSS oil pump
Forced Induction
Tork Tech Terminator Kit
- Stiegemeier Stage 6 Ported Eaton M112
- Air to Water intercooled
- Lightning Heat Exchanger
- Lightning Bosch Water pump
- Tork Tech Reservoir
- AIS Stage 1 kit from RobertP
- Dragon Throttle Body and Plenum
The block and rotating assembly is finally done and fresh from the machine shop. Since I've been home, I thought I would take advantage of the record breaking weather we've been having in the Midwest and get ready for the NPI removal.
Some pictures...
Picked up some new 18" rims from the Custom Wheel Shop, but what kind are they?
2004 GT Trans and TC. Waiting patiently for the DirtyDog.
140 speedo
Triple pod with Aeroforce gauge from RobertP
4/28/11
Before Picture:
01-10-2012
Thanks for looking!
Josh
Engine Block
97 Cobra Teksid
Cobra Crankshaft
Eagle H-Beams
- Ferea Valves
- Comp Cam Springs,
- GT rockers
TSS oil pump
Forced Induction
Some pictures...
140 speedo
