tranny need help asap!
1quk50
well guys the t-5 went to crap on me..
this is my daily driven car... but i also like 2 race 1 or 2 times a year...
so what is a good tranny that will not mess up on me...
im on a budget....
thx andrew
Jrgunn5150
I have an HD T5 that is very nice for sale in the classifieds.
What's wrong with your current trans?
Addermk2
with the power you are making... the T5 should have lasted you plenty long...
sounds to me like you just cant drive!
*reason* My T5 has held up to my 5k drops while out racing... and I have a 347 stroker making ALOT more than 280-300
Jrgunn5150
Abuse is the killer of most of them for sure.
1quk50
i cant drive? hmm, see the problem with that is i bought the car and i noticed the tranny was whining but i always heard they made a little noise. so i thought nothing of it. well as i drove it more it started getting worse. this is daily driving not ball to the wall driving... then i went to the strip 1 time and launched a 3k on street tires and it starts to whine..
i can drive very good... and i would love to match my driving to yours any day...
so what im saying is the girl that had it be for me couldn't drive. but i gotta fix her mistake.
andrew
Jrgunn5150
Most people can't drive even when they think they can, and this is not directed at you per se 1quk50. I've just noticed in general that popping the clutch and driving all aggressively tends to make your average person feel like John Force or something, when they are probably just simply beating on the car.
So your trans is whining, have you even checked or changed the fluid level?
1quk50
yes sir it had royal purple manual tranny fluid put in when i changed the clutch.
Paul
So tell me, exactly how does "knowing how to drive" save your T5? I'm curious since you seem to the be the expert.
95 svt cobra
well i think for starters you should elaborate on your problems a bit more, it could be something like a broken shifter fork and they are right abuse will def. break a t-5 but to me it seems like your situation you just got one that was on the fringes of that line and normal driving pushed it over.
1quk50
its an imput shaft it whines in every gear except 4th...
but i would like to know.. would it be good to go buy like a rebuilt tranny the has alloy gears in it?
or do a swap? but i've only got about 800-1000 to spend....
Jrgunn5150
I believe it has a larger diameter, sometime around 99-00 the provision for the driver gear went away on all transmissions, auto or T5. However, any 94-up V6 trans will work, and they are all "wold class" with the high alloy gearset.
1quk50
so what should i do guys?
order stage 2 everything for my tranny?( 400 hp and 400 ft lb tq)
and rebuild it myself?
or buy a used one and put it in and save for a swap?
Jrgunn5150
Stage 2 from who? Don't let some company sell you crap you don't need man, but yes, I would just rebuild it myself if I was you.
1quk50
astro performance..
i saw em in my mm&ff mag...
either them or d&d is who i m gonna buy off of... which ever give best price.
