tremec?
tuffenuff1222
came across a parts car, 90 gt foxbody built 5.0, if i get the car i plan to swap the motors and all the car has a tremec. i know the fox and the 94 95 t5s are different. what will it take to make the tremec work?
Steven
SC
if it's swapped in already, with the bellhousing and all, you can drop it in as it sits, and then just use a small driveshaft spacer from say steeda or whomever.
Addermk2
he gave you the right answer. you need ALL the parts off the fox, minus the crossmember.
you will need the mount relocation plate off your stock transmission... and a 5/8" driveshaft spacer. Steeda sells one, its about $60
speedyhank
bakewell,tn
i didnt use a spacer so before u waste the money for something ur not sure youll need . put it in then if u need it buy it
Steven
SC
If the driveshaft is to short, you'll destroy the tailshaft bushing
Jerry santos
