i did a search but couldnt find the answer i was looking for.. will this top end kit work on a stock 95 bottom end with out any flycutting.. thanks for the help guys.. :banana:
yes it should without a problem. if you have any doubts, call trick flow directly, they have a great teck line. i talked to them almost daily for a week, and they knew everything i asked.
A kid i know bolted that kit onto his '95 GT and ran into a few issues, I know he ultimately had to get an intake spacer resulting in the need for a taller hood. I think he had a problem with the valve cover and alternator hitting also.
i had those problems with my set-up. i adjusted the dowel pins the the alternator bracket, and out in a 1.5" spacer below the upper to clwar my valve covers. my upper intake slightly taps the hood.
