Trouble starting after engine is hot
Austinx56
Daphne Alabama
So it fires up cold fine but sometimes takes like 7 seconds with the key turned to fire up?
Replaced plugs wires, new dizzy, new starter, replaced coolant temp sensor, thermostat... car sits a lot.
upgraded like you had 19 lb and now have 24? Or just replaced/upgraded? If you switched the lb rating on the injectors did you get a tune or at the least a weighted maf?
Austinx56
Austinx56
Daphne Alabama
Yes 24 and tuned and all
It fires up in half a second cold, but still giving me trouble hot... maybe tfi module?
it could be any number of things from the fuel pump getting hot and not supplying as much to the standard dizzy/tfi issues. I was having exactly the opposite problem and figured it out to be the voltage was dipping JUST below the threshold it needed to be at to start and it took a while to find/figure out. Still not sure I have it fixed really....
BigBore96
Try a better ground wire by the battery that bolts to the core support up top by the radiator on the drivers side.
So many hot start problems are linked to this little wire that gets old, corroded, and overlooked.
Austinx56
Austinx56
Daphne Alabama
This will be my next try thank you
najay
There are starting injector values (multipliers) that need to be changed when installing larger injectors. I had the same issue when i put 60lb injectors in.
next time its hot, try turning the key on 2 times and waiting 6 secs to let the fuel pump prime. It could be getting hot and then not supplying enough fuel or pressure for a number of reasons.
Austinx56
Austinx56
Daphne Alabama
Thanks brother I haven’t had a chance to try all these Solutions yet but will definitely try this also!
Thanks again man happy holidays!
Carolinastang78
