troubleshooting CEL P0171
scarface
I dont have any vacuum leaks, and my MAF sensor is clean.
I did notice however a pretty good exhaust leak on the passenger side manifold/xpipe joint.... you think that could cause this code? Maybe the o2 sensor isnt reading correctly because of it? I noticed the leak after the clutch install, and thats when the code came on too.
any thought?
blackfang
An exhaust leak will cause a lean condition being there is more air added now. I would fix that leak first, then reset the ecu and see if it changes.
97blackgt
This Pinpoint Test is intended to diagnose the following:
Heated Oxygen sensor (HO2S) /Heater
HO2S Connections
Vacuum Systems
Fuel Injector(s)
Harness Circuits: HO2S GND, HO2S, INJ 1-8, VPWR and SIG RTN
Powertrain Control Module (PCM)
check intake/ PCV valve
MAF valve
blackfang
I say fix the leak in the exhaust first and see what that does before trying to find other concerns. Go with the obvious first.
scarface
thanks guys...Ive checked everything on that list. Its all in working order.
I have bought the gasket, should be here tomorrow. Im confident it is that though. It started right after I removed the xpipe to fix my clutch. no leak before, no CEL before.
now leak, and CEL.
I will report back.
97blackgt
any ideas yet scarface...funny thing is i now have a check engine light also, wich i think is due to an exhaust leak on the passenger side manifold. When i trying to take the x pipe off i stripped the nut, and now only one nut is holding the manifold and the x pipe together. I think it is the leak which is causing the problem, just wondering if u fixed yours yet?
scarface
I havent fixed it yet...I did get the gasket, but Im sure it is the problem...it all happened too close to be coincidence.
97blackgt
how much did the gasket cost you and where did u get it...i might also have to invest in one.
97blackgt
do you think the ford dealership would have them in stock? and a ballpark for the price?
scarface
yeah, but Randy is a ford dealership, and he sells at cost. probably around 14 bux or so.
97blackgt
ohhh i got ya...should be fixing mine tomorrow as long as i can get my car to the auto building...supposed to get 8-12 inches of snow :eek: :(
97blackgt
fixed mine also....i forgot to post though
now i have another CEL for an 02 sensor :-\ :nonono:
