Tunning and Cleaning
SN952NV
I saw the post by Matt94GT wich defanantly brings up some good points. Cleaning the MAF IAC and bleeding air out of your brakes. Im honestly going to say that none of this besides normal maintanance has ever been done since I got the car... and well I want to do it. Never done the brakes before and the IAC and what not.....what are some easy steps or important pointers?
scarface
Guest
clean the parts with a spray electrical cleaner, take them off, spray them clean, reinstal.
Brakes-
*Jack the car up, support it, remove wheel.
*Look for the bleeder valve on the caliper. with the car off, have someone pump the brakes until the pedal is hard.
*tell them to hold the pressure on the brake and crack the bleeder open.
*Once the brake pedal goes to the floor, tighten bleeder. tell friend to let up on the pedal...repeat until there is no more air coming out of bleeder.
*move on to next brake, repeat.
Dalamar
SLC, UT
Brakes-
Roger that.
and remember to make sure the fluid in the master cylinder stays topped off as your bleading it.
If you suck it dry, you gott start over. :)
scarface
Guest
or you could purposely suck it dry, and replace the fluid with all new stuff :)
SN952NV
nice...thanks ya ill prob just flush the whole thing... my rotors are at the end of their life so ill most likley just be lookin for slotted rotors and lines... who :boink:
Dalamar
SLC, UT
That's good stuff :lol:
I like when the guy pints a says "vhat does dis DO?"
lol
On Wayne's World, I'm pretty sure they say "it certainly does suck"
gotcha, movie man!!
FlyBy347
