My turn signals will not work unless I press in the hazard light button. If I just press the hazard button the lights don’t blink. The possible culprit is that I recently had my instrument cluster out to replace the odometer gear. I was thinking that the connectors on the back of the cluster may not be seated but all the instruments work – the turn signal indicators correctly show which turn signal is blinking. I don’t think I disturbed any other connectors but it was tight. Since plugging the cables into the cluster is a bit of a PIA so I’d like to not just pull it out / install it again as a debug.
