A big problem that many overlook and/or ignore is adjusting your headlights. You may have the greatest headlights(halogen, LED, HID) but if they are not properly adjusted, you will still have crap. I will park on the dark side of a building(Walmart, Costco, the local Chick-fil-A, etc) in a level parking lot at night with my low beams on. I adjust them so that the levels of both sides match and that they shine parallel with the surface of the parking lot. If your headlights are centered 23” at your bumper, they should be the same at 50’ from the bumper. This is what they are designed for.
True.A big problem that many overlook and/or ignore is adjusting your headlights.for.
Not quite true.If your headlights are centered 23” at your bumper, they should be the same at 50’ from the bumper. This is what they are designed for.
So, popular opinion is the LED bulbs won't work in reflector housings. That was true once upon a time, but the current crop of new technology is significantly different. There are newer bulbs will work quite well in a reflector housing, without tons of glare or crappy light patterns. Not saying that a quality projector housing isn't going to offer more performance, just that the LED's are a big improvement over stock or high performance halogens. Check out this video - very informative:
