Upper Control Arms...
sk8inrj1
I am thinking about getting BBK's upper and lower control arms because I found them for cheap. I wanted to know if it would be ok/safe to run bbk's upper control arms with their urethane bushing on the chassis end with stock rubber bushings on the axle end? This will be for a 1994 cobra with stock engine, 3.73 gears and lowering springs.
94Pro-5.0
Little Elm, TX
everyone, and i really mean everyonbe says not to use aftermarket uppers, becasue they create inwanted binding, casuing stress to your torque boxes and floor pan. if you got a good deal on the arms, put on the lowers, sell the uppers, and buy FRPP uppers from ford, they are cheap. I have lakewood lowers and frpp uppers and my car has no binding. soon i plan to get steeda weight jackers though :)
jfor441
If you use the uppers you want to make sure that you weld up the torque boxes. They are just spot welded from the factory. I would also recommend you getting torque box reinforcements. Basically they are just steel plates that get welded into the torque box area. Will keep you from ripping torque boxes out.
jfor441
95-stang said:
Looks like the stockers will be going back on then.
Yeah LOL... Really no big need to for the UCA unless you are planning on drag racing and launching hard.
Dalamar
SLC, UT
Good call!
I'm glad you mentioned this.
jfor441
I have heard and seen too many pictures of folks with stock motors and they put upper control arms and 2 launches on the strip and they rip out the torque box. Just not something that is worthwhile unless you are serious about racing.
Dalamar
SLC, UT
ya, cheap parts never pay off when you push it.
a correctly engineered suspension part should never bind.
Have you read the sticky in this forum - check it out and post up your input. :)
jfor441
Yeah I have read the sticky. That's too much info for me. All I care about is going straight! :rollinglaugh: :rollinglaugh: :rollinglaugh:
SRT Handz
Quoted from MM's site.....
"We performed extensive testing of rear upper control arm bushing materials during the development of our Panhard Bar. When retaining the original four-link suspension, the best compromise between resistance to suspension bind, best control of axle position, best ride quality, and least potential damage to the chassis, is to retain rubber bushings in the rear upper control arms. This is especially important when adding a Panhard Bar. The compliance of a rubber-bushed upper control arm is required when a Panhard bar is added to the Mustang four-link suspension."
topless95
I am not trying to start anything, but why do most UCA manufacturers include poly bushings with their arms???Why wouldn't they include the rubber bushings, unless they make the torque box kits as well :rollinglaugh:
Dalamar
SLC, UT
Because it's a Cheap fix to the sloppy factory 4-link arms & bushings - but only good for going straight.
They cause bind because the 4-link suspension also moves in an arc as it moves up and down.
it's an old, flaw'd design from ford, and all mustangs have it up to 05, except the irs.
topless95
Wouldn't it be better to use UCA's with spherical ends(if available), sort of like what 4x4 4 link's use???
SRT Handz
people do use this.... but they have Zero Flex or give so they are torture on the Torque Boxes
jfor441
ANY aftermarket UCA is going to stress the torque boxes. They are just spot welded. You can strengthen them some by welding them up and then welding in torque box reinforcements. Unless you are going to be doing any serious or regular drag racing aftermarket UCA's are kind of pointless.
Dalamar
SLC, UT
I've never seen that on the uppers.
It's kindof a twisting action, and I know MM has tested this and reocmmends the stock or ffrp arms for that reason.
there's more info on it on Mm's site and teh Mirros link in the sticky in this forum.
What's best is MM's LCA, BC their busings are better, and arms strong, then adding an external stabalizer, like a panhard or whatts.
or going to the 3-link, like I did. :)
but for most street drivers, LCA's and other upgrades are good enough. depends on how far you wanna go.
topless95
Gotcha, I appreciate the info :thumb:
