UPR tripple pick up
tommybunz
just got the upr pick and when i installed it there was a lot of play it is this because the motor is not in the car, or is it a must that i use the firewall adjuster. Also when i push the clutch the cable comes off. and do i need to bend the spring that makes the P U fly back
scarface
you need an firewall adjuster, or adjust the clutch cable down at the shift fork.
monkeydude3
Illinois, USA
I had that triple hook thing and it kept cutting the cable.
I went back to stock on my old car and it worked fine for me
scarface
you didnt have it installed correctly then. You need to shim it to make the cable centered in the firewall hole.
scarface
hold the solid part of the end of the cable (above my fingers) and tighten the nut at the end of the cable. Tighten until you have about 1/8 th inch of play in the clutch fork.
monkeydude3
Illinois, USA
I did, it was.
Anyhoo that car is gone now so whatever. Onto the next one.
ryclef331
Which hook are you guys using?!
One of the hooks isn't meant to be used. The third hook was added so they could copy steeda double hook quadrant with out getting sued and to make it LOOK like they were offering more.
wytstang
Same here (2 OEM cables at that) I have a Fiore waiting to go on. I was using the 2 hook as well. I'm taking the UPR junk off and Steeda FWA/Fiore quad is going on instead.
Schiffy
Norfolk, Va
I've got the UPR Triple pick up... swapped it out for a GRIP Aluminum pickup that the previous owner installed. I haven't had a problem with it. i've got the cable on the middle hook. :dunno:
purplehaze
i am on the hunt for a good quadrant but dont know much bout them and what the difference is between the triple and double, speed release. can someone give me a good quadrant to buy and which hook to have it on thanks.
EdgarR213
Staff online
