V6 going Duals question(s)
UltraKla$$ic
I have a '98 3.8L and want to go to true duals. What will I need to accomplish this? I'd like to go with an X-Pipe setup from cats back but am unsure of the '98 configuration to do so.
Any help would be greatly appreciated. :thumbsup:
atlanticblue98
an x pipe wouldnt be true duals, it would be duals but not true dual. true duals have no crossover pipe connecting the two pipes.
whitefang98
i have true duals which is just two separate pipes going straight back from your cats. on my exhaust i have flowmaster 40s on and its sounds good!
MadStang
Escondido, Ca
an x-pipe will make your car very raspy, check some vids on youtube. the best sounding is definitely an h-pipe with flows.
http://www.youtube.com/watch?v=tzz99AV6mX0
True Duals will give the raw engine note which I love. It's all up to you. All you're going to need are the mufflers, tips, and cross-over pipe (if you decide), and just have an exhaust shop fabricate the rest.
Mr.Bolt-on
I say go with an x-pipe with high flow cats, because it flows better with the x cross. H-pipes don't flow as evenly, resulting in the lower rumbly noise you hear. It's up to you, but I had a 1998 v6-mustang with jba short tube headers, highflow cat X-pipe, with dual flowmasters, and it sounded really good. Also after 3500 rpm on any V6 it is going to sound raspy wether you have an H-pipe or an X-pipe. X-pipe just flows better.
Also I'm not hating on the H-pipe, my 5.0 sounds great with one.
U
UltraKla$$ic
How would it sound and would I lose any power if the muffler shop just cut my pipes behind my Cats welded in pipes and mufflers all the way out the back?
g36 monkey
Orlando, Fl
i went to a junk yard and picked up pipes off of a cobra (like 96 or so) for $20 and had them put on my car with a custom H for another $300 or so.
its all removable though which is nice in case it has to come off.
i think mine sounds pretty good, the videos i have for it suck but ill post them anyways.
girlfriends camera is broken and mine doesnt record sound ha.
so terrible sound quality, but hopefully you get the idea.
feel free to comment
o and mad stang, yours sounds sick
