valve cover fill neck.
QCmustang94
I just did an H/C/I on my car. I cut the fill neck on the valve cover and blocked it so I don't have any vaccum on the valve cover. Can it cause bad idle? If so, is there a way that I can remain to this?
Q
QCmustang94
Will I have to drill an adapter in it to route a vaccum and block the fill neck after?
blkmcnasty
Illinois
Are you using the stock valve covers?? If you are then i would switch to aftermarket and just use a breather filter. Looks better and is functional.
Paul
Yes. I did the same thing once where I blocked the small breather tube that runs from the valve cover fill to the air inlet. Had a weird idle. Re-attached it... fixed.
Paul.
Q
QCmustang94
yeah... The problem is that the small breather tube isn't there anymore. If I drill a tube directly in the valve cover, do you think it's a good idea?
Paul
Drill a hole in the valve cover for a breather, then get a breather with a port in it, and attach it where it was.
Paul.
Paul
No, just look around on summit. I'm sure there's a million of them.
theres a write up around here somewhere about the pcv system. cant seem to find it right now. however in that write up it explains that the tube going to the oil fill neck is actually how the pcv system draws fresh air into your engine. basically with out that hose you are causing improper pcv function. if you would happen to use just a breather that is technically a vacuum leak and can cause poor idle. good luck
