Valve cover options
Canary95GT
I'm assuming that i will have valve cover clearance problems with my 1.6rr with stud mounts.. So I emailed canton and they say their valve covers will work and i will not need a intake spacer.. Is this true and has anyone tried one? Also I like the look of the trick flow valve covers if any of those work with my setup could anyone give me a parts number.. eBay seems to be the way to go ...
Addermk2
tfs covers SHOULD work without any issues. the main problem SN-95's have with valve covers is actually the alternator. Most aftermarket covers hit the alt, and wont line up properly.
Paul
Stock fox will work.
I have a set of TFS covers sitting in the garage. Don't know if they'd work - they look sorta tall.
Paul.
det_riot
Dearborn
i have these on mine with 1.6 rockers and trickflow heads
I did have to run a 1 inch spacer fwiw
C
Canary95GT
that looks good man.....i see alot of fox style on ebay....i really like the look of the trick flows, if i get a set that fit a 87-93 will they also work for me
Paul
Mine are just stock fox ones that I sanded down until they are smooth, bead blasted, and powdercoated myself. I sold a couple sets to some folks on this forum.
The TFS valve covers appear a little taller, and have the ugly 1980s-ish logo on them. I'm not sure if they would fit without a spacer or not. Perhaps someone else can chime in here.
Not all valve covers will fit because the alternator housing sits much closer to the motor on SN95s, and hits the front of the passenger cover.
Paul.
Copy and paste, from my outbox.:
Javi said:
Fox valve covers will work but you have to modify them,grind off the oil baffles (spell check)also stack 2 gaskets.
Also, i thought the trick flow will work,but i cant confirm that.
C
Canary95GT
Alright well I will be looking to pickup a set of fox style then... No one has used blue oval industries or canton covers ?
I just sold a set of fox valve covers this morning for 30 shipped. Not the powder coated lol
I practically gave them away.
P
panther007
i just bought a set of tfs valve covers what options do i have as far as the alternater working? or is there a aftermarket bracket i can get?
Paul
If it hits the alternator, the only options I'm aware are to grind the valve cover, or the alternator casing, or cut the valve cover, notch it, and weld a plate in. I had that done to my old Ford Racing valve covers and it worked like a champ.
It's easier to just buy valve covers that actually fit.
Paul.
Paul
panther007 said:
summit said they would fit.and i fixed my sig damn it was huge huh
Summit techs are about as smart as a Bonobo monkey with Down syndrome. Listen to us, not them.
I asked them for some info about a cam a looooong time ago, and informed them it was for a 418 cubic inch Ford motor. They told me those don't exist. :tard:
Paul.
Rice_slayer
Your sig is still huge panther lol. I run TFS valve covers, they fit just fine, I run a 3/8" spacer though, if you don't the EGR I believe hits the valve cover, it was that or the intake elbow.
