valve cover torqe pattern?
mtang98 gt
Is there a certian torqe pattern i need to follow when putting my valve covers back on? if it helps i have romeo heads
duff daddy
Position and, using Gasket and Trim Adhesive F3AZ-193508-B or equivalent meeting Ford specifications ESR-M11P17A and ESE-M2G52-A, secure new valve cover gaskets into valve covers and install valve covers onto cylinder heads.
Install bolts and stud bolts into RH valve cover. Tighten all bolts and stud bolts to 8-12 N-m (71-106 lb-in) .
Install bolts and stud bolts into LH valve cover. Tighten all bolts and stud bolts to 8-12 N-m (71-106 lb-in) .
That is directly out of All-Data Pro.
I will check my Ford Manual and get back to you tomorrow.
duff daddy
No spcified sequence, start from the middle and work your way out evenly is the accepted method.
