Valvetrain chatter
BigSkySN95
I'm getting alot of valvetrain chatter at idle from the passenger bank. This is a stock 5.0, what can I do to quiet it down? Thanks
LAFENATU
I would put my money on the oil pump is dying or is dead and oil is not making it all the way up..
Or
The screen is clogged.
A bad lifter would be suprising. Ford lifters hardly ever go bad. It is not common especially the h.o. Roller lifters..
.02
LAFENATU
BigSkySN95 said:
72,000 miles, Mobil 1 10w 30
It can happen man..keep in mind the car is 14+ years old..
you can drain the oil...put 4 quarts in and 1 quart of lucas stabalizer..see if it helps.
B
BigSkySN95
Is there a way to test my oil pump? The gauge shows good pressure but that doesn't mean much with the stock gauges.
LAFENATU
I would say when the motor is still cold about 40psi should be decent..
The last rebuild I did on my old 92 lx the car made 65psi cold, that was a fresh motor though..
.02
blacknasty
my oil guage moves from either in the middle somtimes around a 1/4 in the guage window if its idling low is that normal? it doesnt leak or blow blue or anything
LAFENATU
It moves back and forth - like surging?
topless95
Is it a gauge indicating actual pressure(autometer) or the stock gauge?
LAFENATU
That's why I recommended the lucas oil stabalizer.
It's pretty thick and might help..
