vert drain?
Gregor185
New Tripoli, PA
my dad has a 00gt vert and weve been hearing water sloshing around in the back where the top sits and right below that...is there a drain back there??
Whitepony
Fill your tank up all the way and have a listen. Otherwise, water should not get inside. I guess its possible the innerliner is creating condensation? No drain that I have ever herd of.
5litrarag
No drain back there.... better get in and get that water out. You're top is leaking somewhere...probably near the lower corners of the rear window.
Barner1
Tennessee
Make sure it's not water inside the car. Get in the back seat and look below the window in that black vinyl part behind the back seat where the top goes when it's down. Mine use to collect water back there because the back window wasn't sealed up good. I could always tell when it had rained and I didn't know about it because the first corner I would take, I would hear water sloshing around. Hope you figure it out bud.
JerZeyStangz
Northern NJ
You gotta replace that back window seal because when it rains the water pools back there and the interior will start smelling moldy
5litrarag
Whether or not it was replaced, which does not mean its sealed correctly. You better look behind the seat and in the trunk and make sure theres no water back there.....
ivan12
Take the trim off and make sure that the top isn't ripped or that its attached right. The guy that installed mine last time did a real shitty job and didn't install my top right and everytime it would rain all the water would collect in the rear and find its way to the rear floor section.
Jerry santos
