So my brother in law just bought a 94 Gt, If you drive it normally down the road nothing happens, If you floor it the coolant sprays out of the overflow bottle. The cooland was brown so. I did head gaskets. I didn't see anything that was obviously wrong with them which was the odd part. I used P9333 when I changed them and now it is doing it again? I did a compression test everything checks out. If you just drive it everything is fine temp, oil presssure everything. When you floor it all gauges are fine, doesn't break up at any RPM level. My best guess is either a cracked head or crack in the block. Any thoughts?
