VHT Nite Shades??
Win
Kennesaw, Ga
Hey guys i was about to order a can of this but i was wondering if you think i ought to get 1 can or 2. I think i ought to go with 2 just to play it safe. Although we really don't have too much coverage on the 94-95 tails that's why i was questioning this. So what do you think??
ARdoller
-Never Forget-
i did these in less than one can. you should be fine.
jc95gt
yeah took me less than one can...
i need to take em back out and give em a clear coat
but it was a pita taping around the lights
ARdoller
-Never Forget-
dont bother with clear coat, just get yourself some polishing compound, some 1500-2000g sand paper and a small orbital buffer. it will come out much better than clear coat. you have 2 options to shine out tail lights, one being clear coat, the other being just polishing, or even a combination of both. but what most people dont realize is that just using clear coat, isnt going to get rid of all the orange peel. if you want them to finish out correctly, you gotta treat em like paint, where the quality of the job is 99% in the wet sanding.
granted, on those i posted above, i used a 7" variable speed polisher :p
justinschmidt1
+1
Clear coat blows on vht night shades, get some 2000 grit and polish the shit out of them, YOU NEED A MACHINE THOUGH!
jc95gt
huh,
well in that case ill just buff em on day at work
and mine are pretty shiny now, so it should look scweeeeeeet
x182dan
Your gonna wanna clear them. Mine look perfectly mint and I cleared them. I did polish the crap out of them also. You do not need a freakin machine, yes it makes the job easier but most of us won't have a machine to use.
ARdoller
-Never Forget-
a 6" orbital buffer from Pep Boys/AutoZone is all you need.
when i use a 6" buffer it takes me about (im guessing since i dont do it all at once) about 8 hours of buffing. i decided to use a foam pad on my 7" polisher this time around on 2 or 3 sets, and it took about 20min each.
believe me, being someone that DOES NOT have professional equipment like paint guns and other body shop tools, you can easily do this yourself without HAVING to use clear coat, without it taking too much effort.
this is an up-close picture of them, to show you how shiny and reflective they can get withOUT clear coat.
now im no expert on clear coat, so maybe i was doing it wrong, but being that i dont do this for a living so i dont have the "ideal workspace/tools" that you would want, every set i do i usually experiment with a different method doing stuff. that being said, i have tried clear coat, and like i said im no expert with clear, but every time i tried clear coats, it was just very unpleasing.
x182dan
Ohh I'm not doubting that yours came out mint because it looks good. Just because someone does it this way doesn't mean you cannot do it that way. Mine look just as good as yours and I used a clear coat. I've had a buddy follow the same directions I gave him with the clear and his came out equally good. I wouldn't say clear it and leave it alone. It probably wouldn't be much better than without the clear if you did that.
W
Win
Kennesaw, Ga
So with or without clear :) I have some 1500 and 2000 grit from we sanding my headlights so treat it the same way I would wet sand headlights. Sorry I'm posting from my phone at work
justinschmidt1
Post pics of these tails that look "just as good as his"
ARdoller
-Never Forget-
how did you apply and finish out the clear coat? all the methods i tried didnt produce very good results. at least no where near the results of just a good polish. are you using a paint gun or just rattle can clear?
im not saying your way is wrong, or my way is the only way to do it... especially considering i try slightly different methods all the time. im more-so just trying to find an answer as to how you have to apply clear coat for it to look correct on tail lights.
the only way i would say would be "incorrect" is if you dont do anything about the tint itself once you apply it, because you have to get rid of the orange peel somehow to get a clear shine and optimal light output. (im not directing this towards you because you seem to know), but obviously cant just spray the tint, spray the clear, and just leave it... because youre doing nothing but masking the dullness of the tint rather than polishing it out.
for those that arent familiar with the process, when im wet sanding, i use the simple "finger/open palm test" where once the surface feels like glass, or like a clean paint job, then you have at least gotten rid of the orange peel. from there they should haze over to an almost milky white color, to which you then just take a buffer/polisher and go to town until they go from hazy white to translucent tinted red.
justinschmidt1
Ive had similar results with clear, they turn whitish, hazy, etc sometimes
They look far better wetsanded with 2k grit and polished IMO.
ARdoller
-Never Forget-
yea justin, i know ive talked to you about this before, and from what i remember neither of us really had a good answer to using clear coat. pretty much being why i stick to just a simple wetsand and polish.
justinschmidt1
I wouldnt use clearcoat UNLESS I had automotive grade clear that I could apply with an air gun.
Otherwise It seems like more trouble than its worth.
