Vibrating Clutch Pedal
STLCobra23
I noticed today while driving that my clutch pedal has a rather annoying vibration. It get worse and worse the higher the RPM's are. Anyone have any ideas to what this might be? Has it happened to anyone else?
SRT Handz
You shoudnt be resting your foot on the clutch pedal.
Sounds like the TOB is worn and shaking the clutch for or the clutch fork pivot ball is worn causing shake from the TOB
STLCobra23
Well the TOB was replaced about 2 months ago.. Does that matter or can it be worn in any amount of time?
jabird
Just guessing, you had a new clutch installed, right? Did you have the flywheel surfaced? I have found that those pesky hot spots on flywheels can only get worse. Find a machine shop that heats the flywheel as they grind it. ClutchWorld does it for $30. And keep your foot off the clutch pedal! :dontknow:
