Vibrating
miss2slocoupe
Canton, Georgia
Ive noticed if im on the gas pedal on the highway or just driving i have lots of vibrating from the rear of my car? WTF is this!?!
95riosnake
Pittsburgh, PA
Could be a pinion angle problem, I had that issue when I lowered mine more than the Pro-Kit drop I had at first. It could also be a ring gear/pinion depth issue or one of the bearings could be worn out.
When mine had the pinion angle problem, it seemed to only vibrate when I was under throttle. Adjustable UCA's cured the problem for the most part.
RichV
CO
Is it something that started after some bolt on mod?
U joints would be my guess. Take off the driveshaft, take it in somewhere that can replace the u joints and check balance. Or just get a new aluminum shaft.
95riosnake
Pittsburgh, PA
+1 I forgot about U-joints, plus U-joints are fairly cheap and simple to change.
justinschmidt1
justinschmidt1
Check and make sure the drive shaft isnt loose at the back, if they didnt use loctite it will come loose.
Grab the driveshaft and see if it has any play in it, could be bad u joints like others said.
miss2slocoupe
miss2slocoupe
Canton, Georgia
If it is the driveshaft then why would it only vibrate under load? i would think it would do it all the time while driving it.
justinschmidt1
Lol idk pressure? Who knows just check the damn thing. It takes 10 seconds to.jack the car up and shake the shaft
The u joints could just be showing weakness under load
quickstang_1994
Cross Anchor, SC
if it started with the trans then ck everything in that line motor to rearend, personally i would start at the rearend and move to the front and hope its something simple
