vibration after swapping tranny HELP
boosted347
OK I just got my tranny in and changed my clutch(advance stock clutch kit) and had my flywheel resurfaced now I have a bad vibration that goes with the RPMS (Gets worse the higher RPM ) does it sitting still in neutral or not, with clutch in or out, and everytime going down the road when I shift, I push clutch in and let of gas to change gears and vibrates with RPM??????? Any help would be great I am afraid of driving my car like this please help
Ohhh and I have been searching the site and saw alot about the balancers goin bad if my timing mark is jumping around when I use a timing light does that mean it is bad ?????
Trickflow.GT
when i got my clutch done there was a slight vibration but it disappeared after the break in period.
ryclef331
Sounds like a balancer issue but I'm not so sure since you just did clutch work. Grab your balancer and see if you can wiggle it around. If you can, its shot. Look for rubber spitting out. Check your timing like you said, if it is out of the park off, the balancer is toast.
The fly wheel only goes on one way so thats out of the question. The only other thing is if the pressure plate is installed wrong or out of balance. Which is a possibilty being as its a cheap-o parts store setup. Check that balancer first.
B
boosted347
Thanks ryclef331 your a big help I will let you know what I find out I would hate to take the tranny back out that is a b#%$* , someone had a 4cyl tranny in it before found that out when it blew and I was putting my new one in. But I will let you know what I find out thanks again
B
boosted347
Well I just went outside and tried to wiggle my balancer around and no go she is stout.........I geuss my only other option is to put her back on the stands and start pulling the tranny back out :'( :( :mad: :-\ :rant:
B
boosted347
I was able to mount my tranny but in order to do so I had to take my energy suspension mount and slide it back it has slots too. But when I put it where it needs to be it is barely catching I just drove down my road and back then started feeling vibration so parked it. will try to take picture to see if it helps. thanks for the replies
ryclef331
Ok...if you're going down the road...you start feeling the vibe. Throw the clutch it and rev it...does the vibe get worse or stay the same? If its worse, its something from the pressure plate forward. If it stays the same, its the driveline...are you sure those bolts are tight on the driveshaft?
B
boosted347
When I am goin down the road I can push the clutch in and rev and it vibrates..........I just took my tranny back out and inspected the flywheel pressure plate and as far as I can tell everything is fine and tight. the only thing I saw was on the flywheel I only had 2 dowl pins in instead of three the other one was still in the old clutch. but other than that ??? I put the other dowl pin in the flywheel and I will be swapping out my clutch and pressure plate with new one since it has a warranty (just in case) and start putting it back together.............should I go ahead and put a new flywheel on there or.........what?
ryclef331
the counter weight of the fly wheel can't come off...its one piece. Make sure the bolts are tight. Did you verify your timing? The balancer may have slipped man. it can still feel tight but it COULD still spin.
B
boosted347
Well was going to go to bed and saw you made another comment so hell thought I would go out and check over the balancer real good from underneath since I had it in the air and this is what I saw tell me what you think....................
ryclef331
It "looks" ok but the outer counterweight could still have slipped on the hub. You should really actually get a timing light and shoot the timing and see what it reads that will tell you if it has slipped.
As for the pressure plate, if its out of balance, its out of balance. Pushing the clutch in isn't going to balance it out...but I doubt it is that.
